Issue with Client Script not displaying variables
Sami Ahmed
We have an ask to hide certain variables on a catalog item for the catalog & requested item view. It should only show up on the task form view. as per previous recommendations, I have created two different client scripts. One to hide the variables applicable on the Catalog Item & Requested Item view. Another script to display the variables on the Task view.
It works perfectly fine for all variables except one variable. I have recreated the variables and the scripts to see if there is a glitch that prevented it from being added but still not able to resolve this issue.
Script to Show Variables
function onLoad() {
 g_form.setDisplay('variable1', true);
g_form.setMandatory('variable1', true);
 g_form.setDisplay('variable2', true);
g_form.setMandatory('variable2', true);
 g_form.setDisplay('variable3', true);
g_form.setMandatory('variable3', true);
 g_form.setDisplay('variable4', true);
g_form.setMandatory('variable4', true);
 g_form.setDisplay('variable5', true);
g_form.setMandatory('variable5', true);
 g_form.setDisplay('application_input', true);
g_form.setMandatory('application_input', true);
 g_form.setDisplay('application_input_type_2', true);
g_form.setMandatory('application_input_type_2', true);
Script to Hide Variables
function onLoad() {
     g_form.setDisplay('variable1', false);
     g_form.setDisplay('variable2', false);
     g_form.setDisplay('variable3', false);
     g_form.setDisplay('variable4', false);
     g_form.setDisplay('variable5', false);
     g_form.setDisplay('application_input', false);
     g_form.setDisplay('application_input_type_2', false);
Hitoshi Ozawa
Hi Sami,
Tried the script and it worked OK on my instance.
Defined variables as follows. I've set Global to "true" on all variables so it'll be included in the Catalog Task form.
The script are the same as in the question.
Catalog and Requested Items Client Script
 Catalog Tasks Client Script
 Execution result:
Step1: Catalog item view. Only show common field
Step 2: Requested Items view. Only show common field
Step 3: Catalog Tasks view. All fields are displayed as mandatory
Hi Hitoshi
I changed all the variables to Global = True and this solved the issue. Not sure why because the other fields were set to False as well.
Thanks so much.
