M2M - Advanced Reference Qualifier
Kyle Cribbs
Giga Contributor
We are trying to use an advanced reference qualifier for our M2M references to filter to specific "hardware". From reading the forums it looks like "parent" and "current" exists; however, when I do a javascript:gs.error("asd" + parent); I get
org.mozilla.javascript.EcmaError: "parent" is not defined.
Caused by error in sys_dictionary.475b474879f110107f613a6fa3b72983 at line 1
==> 1: gs.error("asd"+ parent);
and when i do a javascript:gs.error("asd" + current); i get
asdnull
What can i do to dynamically filter based on parent or the current record?
Edit for my context:
I have a table called POAM and a table called Hardware. I created a many to many between the 2. On the POAMs form, I have added a related list. When you click edit we are wanting it to show a filter list of hardware.
So in the many to many table, I am editing a reference qualifier for hardware. for testing I am only printing out logs because nothing was working (and it ended up being because current was null). So i added javascript:gs.error("asd" + current);. I then go to the poams table, and click "edit..." on the hardware related list. This should kick off the reference qualifier script (in does) and when i review the logs i get asdnull. So current is null when coming from a related list. Also, parent is not a defined object at all...
Solution proposed is : Hello Kyle, We are placing this case in Solution Proposed, based on the following information. Issue Summary: Related List Reference Qualifier "current" object is returning null Solution Proposed: The behavior you are seeing here unfortunately is expected. Using Advanced Reference Qualifiers containing 'current' with List Collector type variables is not currently supported as the value for current could change and cause unexpected results. Please see the following knowledge article for more information. https://hi.service-now.com/kb_view.do?sys_kb_id=3f807eaedb7e2f009540e15b8a961961 Next Steps: If you feel I addressed your questions properly and provided relevant information that resolved the issue, please accept the solution and close this case. Otherwise, if you have a moment, you may call me or provide additional information in this case so we may further discuss this issue. Thank you, Jeff Menkel Office: +1 407-499-2550 ServiceNow | Works for you
19 REPLIES 19
Yes, I tried on M2M table and its working fine.
Clicking on the Edit button(UI Action) will not trigger reference qualifier on the hardware field. Reference qualifier only triggers when you hit the magnifier on the reference field.
I am not sure I understand what you mean?
How can I drop the field on the form? I only see it as a related list (for the m2m)
Sorry I missed that earlier. If I am understanding you correctly you want to hide the field on the regular form but on the M2M table relatedlist you want that field to be shown. In that case just hide the field on the form and configure related list list layout to add it on the list.
