making variables read only using ACL
pmelmoth
Hi
I thought this should be a straight forward question but I haven't been able to find a decent answer.
We have variables inherited from the Catalog Item visible on the Request Item. Some of those are read-only others are not. This is controlled through Catalog UI Policies.
The thing is, they should be all set to Read Only when the RITM is set to active=false as a blanket rule.
I would expect to do this via ACL but the following rule does not work.
Operation: write
Condition: active=true
Instead I tried this in an onLoad client script:
if (g_form.getValue('state') >= 3)
  g_form.setVariablesReadOnly(true);
That works fine but surely there is a better way.
Any advice?
Cheers
ghsrikanth
In the worst case, you can always go with DOM element id and that will work fine. Good luck
Ashutosh Munot1
This is always a good option.
Ashutosh Munot
