Need sample Project for practice purpose.
psriram
Hello There,
I need to know is there any sample projects available for practicing purpose. I already have the Dev instance registered and i am using udimy site and learning SNOW. I need to know if i can get some Sample projects which will help me have hands on practice. Any help is appreciated.
Is there any site which help me get the videos on creating  a custom application?
Thanks and Regards
Sriram
11 REPLIES 11
you can simply search on youtube with particular module. there are plenty of tutorial available but i would recommend you to go through the book first here in this book you will build a fresh application and that will clear your basic concept as well as you will learn about the development stuff.
psriram
Ok. Thanks a lot.
 Sriram
if i answered your question then kindly mark the answer correct and close this thread.
poco
url was not working
the link is not working; any one advise pls ?
