Problem with Oauth Config
Bart_omiejG_ra
Hi Guys, I'm trying to setup OAuth for my api.
I have created the Application in my dev instance:
Now, when I call:
GET: https://dev83828.service-now.com/oauth_redirect.do
I got this message:
Your OAuth redirect failed. Please check if the redirect URL setup in your OAuth configuration matches your ServiceNow instance URL.
I have tried with, and without Redirect Url, as it is here: https://community.servicenow.com/community?id=community_article&sys_id=91ecea65dbd0dbc01dcaf3231f9619c3
But still not working, what am I doing wrong?
12 REPLIES 12
If my response helped you please mark it correct to close the question so that it benefits future readers as well.
Unfortunately I'm still getting this error:
"Your OAuth redirect failed. Please check if the redirect URL setup in your OAuth configuration matches your ServiceNow instance URL."
Can it be that it not working on dev server?
Did you give the token URL as this
https://dev83828.service-now.com/oauth_token.do
Yes, fixed that to have this oauth_token.do at the end, but still nothing
So what is the error faced?
Are you not able to generate tokens in your current instance which points to dev83828 for getting OAuth token?
