Reference qualifier not working as expected when Assigned To is cleared
tilekarnilesh
Hello ,
I’m working on a Change Task (CTASK) form where we have three user reference fields:
Assigned To-
Change Observer--
Change Reviewer-->
The requirement is that the same person cannot be assigned to multiple fields.
So, for example, if a user is selected as the Change Reviewer, they should not appear in Change Observer or Assigned To, and vice versa.
This works fine when I first choose Assigned To, and then select the other fields — it correctly prevents duplicates.
The issue:
If I first select Change Reviewer or Change Observer, and then try to select Assigned To, the same user is still available to pick.
Thanks in advanced.😊
Ankur Bawiskar
@tilekarnilesh
advanced ref qualifier looks fine to me.
another way is to use onSubmit client script and check this
function onSubmit() {
    var user1 = g_form.getValue('u_change_reviewer'); // Replace with your field names
    var user2 = g_form.getValue('u_change_observer');
    var user3 = g_form.getValue('assigned_to');
    // Check for repeats among the three reference fields
    if ((user1 && user1 == user2) ||
        (user1 && user1 == user3) ||
        (user2 && user2 == user3)) {
        g_form.addErrorMessage('Only unique users are allowed');
        return false; // Prevent submission
    return true; // Allow submission
nawalkishos
Hi @tilekarnilesh ,
I have checked your requirement and tested it in my PDI
 Here is the code that you need to change-
1. Assigned to field Reference Qualifier (advanced) -
javascript:
var excludedUsers = [];
if (current.u_change_reviewer) excludedUsers.push(current.u_change_reviewer);
if (current.u_change_observer) excludedUsers.push(current.u_change_observer);
if (excludedUsers.length > 0) {
'sys_idNOT IN' + excludedUsers.join(',');
2. In change observer field RQ( advanced)-
javascript:
if (current.assigned_to) excludedUsers.push(current.assigned_to);
3.  In Change reviewer field RQ( advanced)
javascript:
Please change the fields name as per your system configuration
if my response helpful please mark as helpful and accept the solution.
Thank you!!
Hi @tilekarnilesh  it should be like the screenshot-
please test and accept the solution if it work and mark as helpful and accept the solution.
Thank you!!
Ankur Bawiskar
@tilekarnilesh
