07-09-2020 04:42 AM
I have a first dropdown field (field type - 'Reference') with 5 values which has A, B, C, D, and E.
I have the second dropdown (field type - 'List'). I need to populate the list collector with all values except what is selected in the first dropdown. So if I select A in the first dropdown, then my second dropdown (list collector) should display B, C, D, and E so the users can choose multi-select from these values.
This needs to work for the service portal.
I tried creating an advanced reference qualifier for the second dropdown where I have this query in the Reference Qual -
javascript:'choice_nameNOTLIKE'+current.first_dropdown;
The above code does not work. If I replace the 'NOT LIKE' with '=' it works. It tried with other operators like 'STARTSWITH' and it doesn't work. It populates all the values.
I am checking if anyone has an idea of how to accomplish this using reference qualifier.
KP
07-09-2020 05:07 AM
I believe first drop down is reference field so it will return you sys_id and as Brad mentioned there should only be one selected value so we have either = oR !=. So, your RQ will be something like this.
javascript:'sys_id!='+current.first_dropdown;
07-09-2020 05:01 AM
So when you used = the list only shows one value - the one you selected in the first dropdown?
07-09-2020 05:17 AM
Right. As I replied to Muhammad, I should reference the sysid and not the choice_name.
Thank you though for your response.
KP
07-09-2020 05:07 AM
07-09-2020 05:15 AM
Muhammad - You are right. Its the sys_id. When I replaced the choice_name with sys_id, it worked like a charm.
Thank you!
KP
07-09-2020 06:46 AM
Glad to be of Help 🙂
-Sharjeel
