ā01-13-2021 03:09 AM
I have a REST API call that is returning JSON that is too big(> 35MB). Now I cannot use the response as usual
response.getBody() as it will only support till 5 MB and max 10 if used a property.
So I have tried the request.saveResponseBodyAsAttachment(file). to store the large json. unitll here its storing and also getting attached to the record.
Now I need to read that file and do necessary action, while doing that I need to store that big content(> 35MB) atleast to a variable. Now SNOW do not allow string object above 32MB.
Now what technique should I use for such cases where the whole content of the big file needs to be use to do processing (create / update ) record.
Abhinab
ā01-13-2021 03:47 AM
there will be some limitations
I would suggest to get the response in chunks so that it becomes easier to parse in ServiceNow.
the maximum attachment size that the system will return for base64 encoding for is controlled by this system property
com.glide.attachment.max_get_size property.
If the setting does not exist it will default to maximum 5 MB.
You can change this standard value as per your need. However, as mentioned in the following KB, this may cause some issues.
Large attachments may cause Out Of Memory errors and performance degradation
ā01-13-2021 09:14 PM
you should ask the 3rd party team on how you can consume their API with the help of pagination and bring in smaller chunk of data
ā01-14-2021 05:09 AM
Hi
The third-party tool do-not have option to have them in chunks due to serialization problem. Along with the data, the sequence is also important which is not guaranteed if chunks are made my thirdparty tool(AWS Config)
So this is something that needs to be done in Servicenow.
I have seen it was done in python, How can we achieved something similar in servicenow.
Abhinab
ā01-14-2021 05:16 AM
Unless their API supports pagination and is supporting to send the chunk in sequence you cannot do anything
ā01-14-2021 05:30 AM
I have an idea, not sure if it will work.
Transfer the big file to a MID Server, that has some JAVA programs or some other language capable to of handling such things and then return those to Servicenow
Second thought, to Convert JSON into excel and then use transform map.
but How can we convert JSON to Excel in Servicenow
ā01-14-2021 06:01 AM
yes that is an option.
I would suggest this
1) consume the 3rd party endpoint from Mid Server only
2) in the mid server using java code send small chunks back to ServiceNow and then write business rule on ecc_queue table and parse the json
Another approach
1) send the big file to Mid Server and then return back the smaller chunks
2) but I doubt on how much large file can be sent over to Mid Server
OR
Another approach
1) Consume the Attachment API from mid server script and get the big file directly by passing the table name, record sys_id
2) then send smaller chunks
