07-27-2018 05:13 AM
What is Script Background & Fix Scripts?
I think both are used for running ad hoc scripts without the use of any workflow object or BR etc. But what is the difference?
- 13,528 Views
07-27-2018 05:21 AM
Hi Swathi,
Fix script is best approach when you install new application or want some data fixes to be running after making some changes in prod. The best feature of fix script is you can monitor it's execution and check the progress and you can kill the transaction as well.
Never execute any insert/update/delete script from script background since if it takes long time the browser will timeout and also if any error comes in the script it may get into some loop.
Mark Correct if this solves your issue and also mark Helpful if you find my response worthy based on the impact.
08-22-2019 07:42 AM
In order to roll back a fix script you can either go to background transactions and delete the running transaction or can update the state to cancelled in the progress worker of the fix script.
09-18-2020 11:53 AM
Swathi:
This question was just brought to my attention. I wrote a comprehensive article on this topic a couple of years ago you might find of interest.
https://community.servicenow.com/community?id=community_blog&sys_id=e81eae2ddbd0dbc01dcaf3231f96194f
Hope it helps.
Steven.
