Script for setting approval from catalog item variable on REQ
Kifrez
Hi everyone,
How do you set approval in workflow?
I would like to set the approver to be from variable?
the catalog item variable is manager and value will be from manager field.
Thanks in advanced.
If this workflow is on request then you should query the RITM details and use them
somethink like this.
var answer=[];
var grScReqItem = new GlideRecord('sc_req_item');
grScReqItem.addEncodedQuery("request="+current.sys_id+"^cat_item=1391a4db070630100b36f6fd7c1ed0c2");//map you catalog item sysid here.
grScReqItem.query();
if (grScReqItem.next()) {
answer.push(grScReqItem.variables.manager.toString());
for below line you should modify the highlated part with the catalog item sysid you want to fetch manager details from.
20 REPLIES 20
var answer=[];
Hi @Rohila Voona thanks that works with cat item sys id !! 🙂
Ankur Bawiskar
I assume your workflow is on RITM table
then this should work fine
Did you add logs what came in manager variable?
answer = [];
answer.push(current.variables.manager.toString());
Hi @Ankur Bawiskar ,
No, this is on sc_request
This is a follow up after the If statement.
No , I did not.
variable name is manager and part of variable set = user_profile_set
manager is reference to sys_user table
I tried below but doesn't work
OR
answer.push(gr.variables.manager.toString());
OR
answer.push(gr.variables.manager.getValue());
then query RITM
answer = [];
var gr = new GlideRecord("sc_req_item");
gr.addQuery("request", current.request);
if (gr.next()) {
