03-03-2022 11:10 PM
Hi everyone,
How do you set approval in workflow?
I would like to set the approver to be from variable?
the catalog item variable is manager and value will be from manager field.
Thanks in advanced.
Service Catalog
Service Portal
Workflow
03-07-2022 11:22 PM
If this workflow is on request then you should query the RITM details and use them
somethink like this.
var answer=[];
var grScReqItem = new GlideRecord('sc_req_item');
grScReqItem.addEncodedQuery("request="+current.sys_id+"^cat_item=1391a4db070630100b36f6fd7c1ed0c2");//map you catalog item sysid here.
grScReqItem.query();
if (grScReqItem.next()) {
answer.push(grScReqItem.variables.manager.toString());
for below line you should modify the highlated part with the catalog item sysid you want to fetch manager details from.
03-08-2022 03:25 PM
Thanks Ankur, that is helpful. it works if cat item sys id is added 🙂
Thanks so much for your assistance . much appreciated
