Sequential Flow Designer Approvals
alona3
I am trying to create a flow which will perform sequential approvals for a record, however after the 1st approval approved it changed back to "Requested" together with the 2nd approval.
1st approver is Manager
2nd approver (3 groups) - approval group will trigger based on legal entity
Can someone advise what is the problem?
Alona
@alona3
so are you saying 1st approval is generated and was approved and when you generated 2nd approval the same approval record moved from approved to requested?
yes, any soution?
@alona3
you will have to debug it from your side and share us the results.
alona3
Already solved this.
