Update Duplicate record using transform map without using coalesce.
DH7
Hi everyone,
Is there any way to update the duplicate record using transform map without using coalesce?
let's say we have target table 'A' it contains record 'rc_1' (ingested via transform map), now again I have record 'rc_1' which contains a few of the fields updated, can I update the 'rc_1' in table 'A' with the new 'rc_1' without using transform map coalesce?
DH7
Hi shloke04,
The use case is to dedup the alerts based on the domain.
We are fetching the alerts from the third-party platform, and we are domain separating those alerts using domain separation plugin. We are storing those alerts into custom table named 'Alerts'.Ideally to dedup the alerts we should use coalase on <alert_id> + <domain> fields. But since we don't have a domain(sys_domain) field in the incoming alerts, we won't have domain field into staging alerts table as well. Hence we are not able to apply coalase on <alert_id> + <domain>.
To achieve our above use case, we are caching(using our app scope in transform script) the domain associated with the configuration from which those alerts are being fetched, and setting those domain value using transform script. Right now we are using the onBefore script that I have shared earlier with primary key as <domain> + <alert_id> which we are receiving in the incoming alert.
Could you please suggest an approach to achieve the above use case without using the transform script?
