Using Knowledge for a Glossary of Terms
06-24-2015 12:11 PM
Hi all,
I'm curious if anyone has ventured into using Knowledge to somehow house a glossary of terms. If so, it would be helpful to hear about how you've structured things -- whether you're, say, committing all terms to a single knowledge article vs. using multiple articles within a "Glossary" KB or Topic... how you're using templates... how you're accommodating terms that have multiple, domain-specific definitions...
If anyone had examples or experiences to share, it would be much appreciated!
-Jeff
Knowledge Management
- 6,125 Views
08-07-2015 11:31 AM
hello,
Now that you have the business glossary, have you been able to leverage that list into other SN Applications?
I need to figure that out in support of a custom knowledge application for master data standards and controls management. It has many HTML fields and often the strategies and background sections have jargon that needs their own separate quick lookup definition. Linking to a KM Glossary inside SN would be perfect.
The App I have is to large to try and build those links manually so I was wondering if you are looking into a dynamic cross reference between your Glossary and other things.
thx
richard
08-10-2015 11:00 AM
We've linked to KAs from other areas in SN but not specifically to the Glossary.
