11-10-2015 09:11 AM
I have a UI Page with a group of Radio Buttons. I can't seem to make the array work because I have a ui_form instead of a form. I need to use the ui_form because I need to use the processing script area. Any help you can share will be greatly appreciated.
<g:ui_form id="ivr_survey">
<table id="survey" width="100%">
<TR>
<TD><SPAN class="normal"><B><h1>Agent Survey</h1></B></SPAN></TD></TR>
<TR>
<TD><SPAN class="normal"><B><h3>I had the tools and/or resources required to resolve the caller's issue to the caller's satisfaction</h3></B></SPAN></TD></TR>
<TR>
<input type="radio" id="score" name="score" value="1"> Strongly Disagree</input><BR></BR>
<input type="radio" id="score" name="score" value="2"> Disagree </input><BR></BR>
<input type="radio" id="score" name="score" value="3"> Netural</input><BR></BR>
<input type="radio" id="score" name="score" value="4"> Agree</input><BR></BR>
<input type="radio" id="score" name="score" value="5"> Strongly Agree</input>
</SPAN></TD>
</TR>
<td colspan="2" align="Left">
<button type="submit" id="submit" onclick="submitChanges();">Submit</button>
</td>
Client Script
function submitChanges(){
var tlscore;
var scores = document.ivr_survey.score;
// var radios = scores.elements.score;
for (var i = 0, len=scores.length; i< len; i++) {
if (scores[i].checked ) { // radio checked?
tlscore = scores[i].value; // if so, hold its value in tlscore
break; // and break out of for loop
11-17-2015 02:27 PM
Here goes the latest. Compatible with IE
<TR>
<TR>
<TR>
<input type="radio" id="score1" name="score" value="1"> Strongly Disagree</input><BR></BR>
<input type="radio" id="score2" name="score" value="2"> Disagree </input><BR></BR>
<input type="radio" id="score3" name="score" value="3"> Netural</input><BR></BR>
<input type="radio" id="score4" name="score" value="4"> Agree</input><BR></BR>
<input type="radio" id="score5" name="score" value="5"> Strongly Agree</input>
</SPAN></TD>
</TR>
</td>
</table>
</g:ui_form>
</j:jelly>
var scores = document.getElementsByName("score");
alert('Selected option value: ' + tlscore);
Berny
11-17-2015 09:32 AM
Hi Nannette, would you like to have a conference call this afternoon to see why it doesn't work on your instance? I'm using Fuji but I'm sure this should not be dependent of the ServiceNow version.
Berny
11-17-2015 09:54 AM
Yes if you're available I would like to know why it's not working
11-17-2015 10:09 AM
11-14-2015 10:27 PM
The key difference is how the score radio button element is referenced to retrieve all its options. Your code will not work just because the form id of a UI page is actually generated on runtime. For this reason you can just directly reference the element by its id and the rest should work as how you have it originally.
I also added an additional alert so that you can that the right value is been selected.
I hope this helps
Berny
11-17-2015 02:27 PM
<TR>
<TR>
<TR>
</SPAN></TD>
</TR>
</td>
</table>
</g:ui_form>
</j:jelly>
Berny
