Where do System Settings data get saved?
Mussie
Hi Guys,
Does anybody know where these details are saved? Thought they are stored in sys_user_preference but apparently they are not.
Mussie
Are you trying to add a language selector for service portal? There is oob language picker widget available for the same.
Once user changes the language using system settings, it applies to all of the instance translations.
Please Hit like, Helpful or Correct depending on the impact of the response
Mussie
Thanks a lot, this will probably fix my issue.
