Workflow Studio - Flow Not Triggering Consistently
‎05-07-2025 05:50 AM
Hi, I have created a flow using the Workflow Studio, which looks at the most recent discovery date to check if a device has been seen in the last 90 days.
I can change the discovery date manually on the device for testing purposes and sometimes the trigger will fire and an email will be sent but sometimes the trigger doesn't fire and no email is created (confirmed by checking the system emails queue)
As shown below I have filtered down to two test users.
Can anybody help me ensure the trigger will always fire.
‎05-07-2025 07:09 AM
Is the flow getting triggered?
Check by manually updating the record which satisfies the flow condition and see the flow execution context and see where it fails
‎05-07-2025 07:25 AM
Unfortunately the flow is not getting executed by changing the record manually, but successfully triggers when running the test on the same computer record and changing the same field name and same current value.
‎05-07-2025 07:28 AM
did you see the flow contexts in executions?
‎05-07-2025 11:38 PM
No flow contexts shown in executions unless ran through test
‎05-07-2025 11:55 PM
Did you check by creating some dummy flow on any OOTB table and see if that flow runs after publishing?
If not then some issue with your flow engine in your instance
Did you check in flow context table if that flow is in "Queued" state?
check these links
Flow are getting queued or delayed execution
Flows are not Triggering when the Condition is met
