How to use one Flow Action output in another Flow Action?
Rajyalakshmi
Giga Guru
2 ACCEPTED SOLUTIONS
Dr Atul - LNG
Hi @Rajyalakshmi
https://www.servicenow.com/community/itsm-forum/how-to-pass-output-of-one-custom-action-to-another-c...
https://www.servicenow.com/community/developer-forum/call-one-flow-action-from-another/m-p/2595501
Ankur Bawiskar
@Rajyalakshmi
you can use "Dynamic Flow" flow logic
Then call your 2nd flow
Then after this you can use "Get Flow Outputs" to get the output in your main flow and then use it
Refer below link
Get started with Dynamic Flow and Get Flow Outputs
Ankur Bawiskar
@Rajyalakshmi
Refer below link
nawalkishos
Hi @Rajyalakshmi ,
you can define action output like below screenshot-
 and you can use it like below-
if you want to create action from scratch then refer below links-
https://www.servicenow.com/community/developer-blog/servicenow-flow-designer-custom-action-custom-ac...
If you found my response helpful, please mark it as helpful and accept it as the solution.
Thank you
Nawal Singh
