ServiceNow Documentation Site is not working
01-14-2026 12:20 PM
ServiceNow Documentation site is not working for past few days as expected .
Some links work some don't .
Can any one provide any input /solution . I am really struggling every day .
Location -USA
02-04-2026 10:51 PM
Hi @Gaurav55
Sane issue with me , use edge as browser or update Chrome browser.
02-05-2026 03:01 AM
Hi @sonalagupta
Yes, this issue is occurring frequently. In particular, when you try to access articles from ServiceNow Support, they are only visible for a few seconds while the page is loading. Once the page has fully loaded, the article shows as unavailable.
The workaround I’ve found is to cancel the page loading as soon as the article appears, which allows you to view it successfully.
Hope my response helps 🙂
Sumit
Technical Consultant
02-05-2026 04:03 AM
Hi @sonalagupta,
I'm having the same issue, tried clearing Chrome cache and relaunching, the docs page still hangs on starting application.
What I have found is opening https://www.servicenow.com/docs/home in an incognito window the page loads fine.
Hope this helps.
02-06-2026 02:55 AM - edited 02-06-2026 03:05 AM
What I have noticed is, that apparently ServiceNow seems to have updated the links(slightly). If you are searching on Edge, it takes you to the old link which errors out. Edge is probably catching up to recognise the new URIs from ServiceNow. Whereas if you use Chrome, the search results seem to point to the right link. For example, when I search for 'glide.identification_engine.update_without_switch_enabled servicenow', Edge search returns servicenow.com/docs/r/xanadu/servicenow-platform/configuration-management-database-cmdb/c_CIReclassification-d70958e17272.html (which does not exist) and Chrome search returns servicenow.com/docs/r/xanadu/servicenow-platform/configuration-management-database-cmdb/c_CIReclassification-d70991e18270.html or servicenow.com/docs/r/servicenow-platform/configuration-management-database-cmdb/c_CIReclassification.html (both works). Notice the slight difference at the end of the URI
