Flow Designer for Project
Jeck Manalo
Hi Everyone,
I created a flow designer that will store the data from stakeholders table to project table field.
My question is If I remove the data on stakeholders table how can be also remove it on the project table field ?
Here is the output. Lets say I remove it on stakeholders how can this data also remove on project table ?
Sainath N
@Jeck Manalo : There should be a "Delete" business rule on the stakeholder table to delete entries from the project table.
Please mark this as correct answer and helpful if it resolved, or mark this helpful if this help you to reach towards solution.
Sainath N
can we just do it on flow designer ? any condition that can be done on flow designer about this ?
@Jeck Manalo Flow Designer supports only the options as per the below screenshot.
ok thanks i will try this one if it will work just leave it empty.
