How to write Script Action in Flow Designer
Rohan04
I got the script for to create multiple RITM from single request based on MRVS and for that they have written Run script in workflow. I have an requirement of to write the script in flow designer. I am attaching the script which is written in workflow.
Your help will we Appriciated!!!
//get  row count for each MRVS row
var rowCount = current.variables.offboarding_user_list.getRowCount(); //This includes the internal name of the multi row variable set which is "offboarding_user_list"
for (var i = 0; i < rowCount; i++) {
//Define variables that will be the same on each RITM.  Add more as required
var req = current.request;
var reqBy = current.variables.requested_by;
//Grab each row of variables that will be different on each RITM
var row = current.variables.offboarding_user_list.getRow(i);
var user = row.user;
var nam = row.full_name;
var num = row.employee_number;
var mgr = row.manager;
//Crete a RITM for each row
var rec = new GlideRecord ('sc_req_item');
rec.cat_item = 'f06761511b582010e8addd3bdc4bcbfe';//catalog item for offboarding line item  NOTE:  This is REQUIRED to kick off the individual workflow created by each MRVS line item
rec.request = req;
rec.request.requested_for = reqBy;
rec.approval = 'approved';
rec.state = 1;
rec.stage = 'request_approved';
rec.assignment_group = 'ea42046613059200a01f3ea32244b0a0'; //sys_id of the Human Resources group
rec.short_description = "Off-boarding for user "+nam;
rec.description = "Off-board this user: \n - Name: "+nam+"\n - Employee Number: "+num+"\n - Manager: "+mgr;
rec.insert();
Rohan04
Hello @Sandeep Rajput I have provided the script. could you please help me out of this?
Hey Rohan, I am facing the same issue.
What did you do to get rid of this error?
Also, did you define variables in Input section or directly in Script?
