Flow Designer – How to allow execution visibility without exposing data from underlying applications
test10
Hi everyone,
I’m trying to design a secure access model for Flow Designer execution visibility in production, and I want to avoid exposing sensitive data from underlying applications.
Requirement
We need certain users (e.g., support teams, app owners) to:
  • View Flow execution history
  • See status (success/failure), timestamps, and duration
  • Perform basic troubleshooting
But we do NOT want them to:
  • Modify or execute flows
  • Gain visibility into sensitive data stored in other applications/tables that flows interact with
I already tried below roles . They have access to go into flow designer, however they are not able to click into flow execution. I'm getting error message that use don't the the appropriate permission.
Out-of-the-box roles like:
  • flow_operator (view execution details)
  • fd_read / fd_read_operations (read-only Flow Designer access)
Tanushree Maiti
Hi @test10
You can give fd_read,  flow_report_viewer role to user and check.
Refer KB: KB2911488 Flow Designer — Read-Only Users Cannot View Flow Execution Contexts Due to Encryption Cont...
Tanushree Maiti
Also check : User access to Flow Designer
Tanushree Maiti
I already gave myself those roles and I'm seeing this error message when I click on the actual flow execution.
Ankur Bawiskar
@test10
flow execution might contain sensitive data such as PII if you are sending to 3rd party or credentials used for integrations
You can use encryption but I think it has limitations when it comes to flow logs etc where we see this information
better to raise a case with ServiceNow for this
💡 If my response helped, please mark it as correct and close the thread 🔒— this helps future readers find the solution faster! 🙏
