flow designer
tushar_ghadage
Hi all
I have a req
If choice A infosys is selected in third party name choice field, then assignment group on the RITM assignment group should be Infosys Employee Recruitment and same for TCS and Capgemini and at the same time these groups will be notified that RITM is assigned for your group.
for this I am using flow designer logic do the following in Pararrel
as seen below have shown for choice A -
but when i select the mentione choice the assignment group is getting seleted on ritm and notification too is not getting triggered
is there something wrong in the flow
please do clarify..
thankss
@tushar_ghadage
Hope you are doing good.
kaushal_snow
Hi @tushar_ghadage ,
If the “Third Party Name” choice field on the RITM is set to Infosys, TCS, or Capgemini, then using Flow Designer the RITM’s assignment group should automatically be set to the corresponding recruitment group (e.g. “Infosys Employee Recruitment”) and that group should be notified of the assignment.
Thanks and Regards,
Kaushal Kumar Jha - ServiceNow Technical Consultant/Developer
