How to develop using RITM without using AppEngine
Mi1
I want to create an application based on RITM.
Until now, we have been developing using App Engine, but this time we need to re-implement the services within the ITSM package(RITM)  without using App Engine.
Do you have any suggestions for implementing what was created in App Engine within the ITSM(RITM)?
Also, please let me know if there are any things to be careful about or any limitations that may arise.
Best Regards,
<------------- add information --------------- >
Thank you for the suggestions.
To clarify my requirements and get more specific advice, please let me add a few points:
1. Table Limit:
We have a strict limit on the number of custom tables (currently 40), which is why we are shifting from App Engine to an RITM-based architecture.
2. "Ledger" Management:
In App Engine, we managed the "current state" (e.g., active user permissions or asset status) in custom tables. RITM is an audit trail of a "request," but I need a way to manage data that remains "living" after the RITM is closed (e.g., updating a completion date or expiration date later by a fulfiller).
3. Data Segregation:
The application will be used by different departments (HR, IT, General Affairs). I need to ensure that sensitive data (especially HR-related) is strictly restricted to specific groups via ACLs, even though all records reside in the same RITM table.
My specific questions are:
• For managing the "current state" after a request is closed, do you recommend using a single "Generic Ledger Table" to aggregate data from various items? Or is it better to manage everything within RITM variables?
• Are there any best practices for implementing robust ACLs on the RITM table to segregate data between completely different departments?
• What are the reporting limitations when using RITM variables instead of actual table columns for long-term data management?
I would appreciate your expert insights on these architectural points.
Best Regards,
Really like the approach related to table rotation and archiving strategy, this would help performance and improve UX.
Related to the question, in one hand; it depends (as always), generic fields would be useful in the technical way and so abstract and scalable, however in terms of reporting could be quiet complex to guess what you are looking at. Maybe you can cover this using database view. Having your main reporting and the rest of the fields as a support fields (just brainstorming).
In the other hand, I've seen a massive table in one client with creating unique fields for each process or need, obviously this it's not good in terms of best practices but they prefer one macro-table with everything needed that many tables accomplish best creation field practice.
If possible, I'll create abstract fields and try to reuse then and scale as possible.
19 REPLIES 19
Dr Atul - LNG
Hi @Mi1
My video will be helpful
https://youtu.be/JN2wVxkAbOg
LinkedIn:https://www.linkedin.com/in/atulgroverservicenowconsultant Redistribution or copying of functionality is not allowed!
Hi @Dr Atul - LNG ,
Thank you for sharing the video!
It's a very clear guide on how to technically generate an RITM from a Record Producer.
One thing I am concerned about is the "Ledger" aspect. While the video shows how to create a request (point-in-time), I need to manage the "current status" of the service even after the RITM is closed (e.g., updating an expiration date later).
In your experience, is it better to manage such "living data" by updating the RITM variables themselves, or should I still consider a separate table to act as a central ledger?
I would love to hear your thoughts on this.
Hi @Mi1
It is not recommended to change variables once a request has been submitted. We need to understand the fundamental concept here: a request follows a standard process and structure. Variables are required to execute the work, and if changes to variables occur frequently or later in the process, it becomes difficult for teams to fulfill the request efficiently. Therefore, we should avoid this practice, as it is not a best or recommended approach.
hi,@Dr Atul - LNG,
Thank you for clarifying the fundamental concept. Your point about not changing variables post-submission to maintain fulfillment efficiency makes perfect sense.
Based on your advice, I am now even more convinced that we should keep RITM variables as an "Immutable Audit Trail" (Request History) and use a separate "Generic Ledger Table" to store the "Current Active State" of the service/asset.
This way, we can respect the standard request process you mentioned, while still allowing the operational teams to maintain up-to-date data in the Ledger without touching the original RITM variables.
Thank you for helping me align our architecture with ServiceNow best practices!
