I have a requirement in a Record Producer where I need to restrict a variable input to a maximum of
02-10-2026 10:15 PM
I have a requirement in a Record Producer where I need to restrict a variable input to a maximum of 100 characters at the time of submission.
The user should not be able to submit the record if the entered value exceeds 100 characters. I would like to implement this validation on the Record Producer variable during submit.
Could you please suggest the best way to achieve this? Should this be done using a Catalog Client Script (onSubmit), UI Policy, or any out-of-the-box configuration?
Thanks in advance.
02-11-2026 10:31 PM
no scripting required, follow what @Shruti mentioned.
02-11-2026 11:23 PM - edited 02-11-2026 11:57 PM
Hi @jeevanjadhav ,
Step1 : You can follow the OOB steps and set the variable length to 100. However, after entering characters up to the defined limit, the system does not allow you to enter additional characters. No error message is displayed, and you can submit it.
Not allow enter further characters.
Step2 : You can create an “on submit” catalog client script that prevents form submission and displays an error message such as: “The variable input should not exceed a maximum of 100 characters.”
On Submit Catalog Client Script :
Please mark helpful and correct answer if its worthy for you.
02-12-2026 02:36 AM
Hello @jeevanjadhav ,
@Shruti already provided solution. Just follow that , that will help you .
Aditya
