Issue with Instance Scan - Table Check for Inactive Users in sys_user
04-01-2025 12:26 AM
Hi ServiceNow Community,
I’m trying to create a Table Check under Instance Scan to identify inactive users in the sys_user table. Here’s what I did:
Created a new Table Check in Instance Scan.
Set the condition as:
Table: User (sys_user)
Condition: Active is false
Ran the check, but no findings were generated, even though there are inactive users in the sys_user table.
To verify, I created a similar check for Active is true, and it successfully found active users.
Has anyone faced a similar issue or know why the scan is not detecting inactive users?
Troubleshooting Done:
Manually verified the sys_user table – confirmed inactive users exist.
Checked if there are ACLs restricting access to inactive users.
Ran Test Check, but still no findings.
Tried using Active is NOT true instead of Active is false but no success.
Would appreciate any insights or suggestions!
Thanks in advance.
08-25-2026 11:51 AM
Ran into this myself today, and wanted to mention there's an alternative, if you're okay with creating a Scan Check using 'Script Only Check' instead of 'Table Check'.
For instance, a script to check for inactive users can be as simple as the following:
(function(finding) {
try {
// Query User [sys_user] table for inactive users
var userGr = new GlideRecord('sys_user');
userGr.addInactiveQuery();
userGr.query();
while (userGr.next()) {
finding.setCurrentSource(userGr);
finding.increment();
} catch (e) {
})(finding);
And then you just to paste that into a new 'Script Only Check' Scan Check record like below and add the Check to a Suite (or click 'Test Check' if you only want to quickly see the results).
