Multirow variable set in flow designer
Servicenow Use4
Hello Experts!
Here's the use case: I have a record producer with a couple of fields and a MVRS. Once the form is submitted from portal, a back-end script runs to populate the MVRS.
I am trying to check if after the record is created, there is any data in the MVRS or not.
I have used OOTB 'Get Catalog variables' action and moved it to available list.
The next job is: If the MVRS is empty, I need to call a subflow.
I'm not sure how to proceed. Can someone please help me with this?
Thanks!!
P.S: I'm working in the HR Scope. The record created is an HR Case. In case this info is required 🙂
So beyond the if statement I showcased that determines if its empty, what are you having trouble with?
Hi @Uncle Rob
I only want to check if the MVRS is empty in the record created. If yes, a subflow should be triggered.
Thanks!
