02-11-2026 10:47 AM
i want to trigger a customer satisfaction servey to every 5th incident caller,when every 5th softwre category incident get resolved,
02-11-2026 07:34 PM
Hi My Friend,
Yep — thats doable, and your right to be thinking about performance.
If the requirement is send a CSAT survey for ~every 5th resolved Software incident dont use a GlideAggregate(count) on the Incident table at resolve-time. That’s heavy and it can also misfire when multiple incidents resolve at once.
What most people do and I have done instead is a 1-in-5 selection that doesnt require counting at all fast + consistent. You only evaluate it when the ticket transitions to Resolved and if its a “hit,” you trigger the survey.
If you literally need the exact 5th / 10th / 15th in sequence, you’ll want a small counter record not an aggregate on incidents otherwise you’ll run into performance + race conditions.
@suryakalam - If help you answer; Please mark Solution Accepted and Thumbs Up
02-21-2026 12:43 AM
Hi @suryakalam
Please refer this links, see if it helps you:
Solved: Survey Frequency - Sent out when every 5th item is... - ServiceNow Community
Send survey after every 5 closed incident? - ServiceNow Community
02-21-2026 01:56 AM
unless you share what you tried and where are you stuck, how we would know what's not working.
share those details
02-21-2026 07:16 AM
Hi @suryakalam ,
Please see the following community discussion, its similar to your requirement:
Solved: Survey Frequency - Sent out when every 5th item is… - ServiceNow Community
If my response helped, please mark it as the accepted solution so others can benefit as well.
