09-24-2026 10:19 PM
I am trying to complete Lab 5.3.6 - Add the second action, but I am having trouble validating the task. It always says, "Please ensure the flow includes at least four actions now". Even though all four actions are enabled.
Task Objectives
1. Add a second Update Record action to your flow.
2. Reference data from actions using the Data panel:
- Move the (1–Update Record) Requested Item Record pill to the Record field.
3. Add the following Field values:
-- State | Closed Complete
To begin, navigate to All > Process Automation > Workflow Studio > Infinity Item Request flow.
Note: Select the More actions menu in Workflow Studio and select Force Save once you are done editing each action in the flow.
Thanks!
09-25-2026 02:46 AM
ahoy @kanavjindal,
you can ask directly the chatbot where you validate your tasks, there are also buttons to get help, have you tried these? It's difficult to debug without the full visbility
4 weeks ago
Thank you kanavjindal for your suggestion. For me, I unselected error handler and not validated the request flow to successfully validate the task. I found this tip from an YouTube video on this topic.
