Approval for project task
rambo1
When approval status is set to 'requested' manually on project task , approval should go to project manager,
I have written a business rule to generate a approval:
var app = new GlideRecord('sysapproval_approver');
app.initialize();
app.sysapproval = current.sys_id;
app.document_id = current.sys_id;
app.approver = current.parent.project_manager;
app.state = 'requested';
app.insert();
Also tried from workflow, but document id field is not getting populated. Please help me wth this issue.
Milind Gharte
Hi ,
Here is a link which will help you.
https://community.servicenow.com/community?id=community_question&sys_id=1f489c48dbb12300afc902d5ca96...
If it helps,Please mark ✅ Correct and 👍 Helpful.
Warm Regards,
Milind
Milind Gharte
Hi ,
Warm Regards,
Milind
WHAT?!?!?! This has nothing to do with what this
