Collaborative Work Management - Concerns About Functionality
02-27-2026 01:07 AM
Dear ServiceNow Community,
As we are preparing to transition from Agile Development 2.0 to Collaborative Work Management (CWM), I am currently working to better understand the new functionality in order to be well prepared for the upcoming change.
I reviewed and examined all available documentation and instructional videos.
I have been exploring CWM in my PDI (Zurich) and have installed it several times for testing purposes. My initial plan is to deploy CWM on a clean instance where Agile Development 2.0 has not been used previously.
Based on my observations, CWM appears to still be under active development, as its behavior and feature set seem to evolve over time. For example, a few weeks ago when I installed CWM, Agile Development 2.0 was installed alongside it. However, when I installed CWM again this week, Agile Development 2.0 was no longer installed, and I noticed that several functionalities were missing. For this reason, I would appreciate your guidance in order to properly plan the implementation.
1) I have reviewed some available timelines, but I would like to understand whether organizations that plan to implement CWM from scratch, without having previously used Agile Development 2.0 - are included in these timelines. What guidance exists for organizations planning to implement CWM between Q1 and Q3 of 2026?
2) I have also observed that CWM stories currently lack several important relationships, such as dependent stories, prerequisite stories, and relationships to related records (for example change requests). Is there a roadmap to introduce these capabilities? Furthermore, is there a planned or supported way to create a story directly from an RITM when implementing a requested feature?
3) I also note that there is currently no application menu for agile-related functionality. Is there a plan to introduce this in the future, including the possibility to open views such as a table of stories, similar to what was available in Agile Development 2.0?
4) When opening the "rm_story" table, I do not see a "New" option to manually create a story. Does this mean that story creation will only be possible through CWM going forward? If so, is this an intentional design decision?
5) During story creation in CWM, I noticed that it is possible to set random ID for story.
At the same time, I am unable to configure the story number field as read-only via form design.
Is it possible to customize the story form to meet company-specific requirements? I attempted to edit the story form using the CWM view, but the changes are not reflected in the CWM Workspace.
6) Additionally, I noticed that fields such as Product, Theme and Release, are not available. Is there a plan to introduce these elements? More generally, what will be the future structure for agile-related data and processes in ServiceNow?
7) I have an additional question: CWM - Why is the “Assigned to” filter unavailable in the Kanban view, unlike in VTB? (I am unable to respond to my own posts in the Community , therefore, I will repeat it here; The question may not be "why it is not there", but rather "whether it will be there").
I understand that VTB and CWM are different products, however, since CWM is intended to be the recommended tool for Agile in ServiceNow, I would like to clarify its capabilities.
I would like clarification on whether it will be possible to filter stories by "Assigned to" during stand up meetings. My original question aimed to confirm whether such functionality exists, whether I may have overlooked a configuration option, or whether there is an alternative approach.
This capability is a critical core feature, as it significantly improves the efficiency of collecting status updates during daily stand up meetings. While I am aware that stories can be sorted by specific columns or grouped using horizontal lanes, this approach does not provide an optimal user experience for stand up meetings.
Thank you very much for your time, review, and any guidance you can provide.
Scaled Agile Framework (SAFe)
- 5,564 Views
03-02-2026 08:22 PM
Hi Joanna,
We have DPR integration in our roadmap but If you wish to continue using the Release, Product and Theme fields, you can add them in the Story platform form by customizing your CWM view to include these fields.
Let me know if that solves the need.
03-05-2026 03:28 AM
Hello @alekhyanema,
Thank you for your response.
What you described, is exactly what I was trying to achieve, however, I was unfortunately unable to edit the entire form and the changes were not reflected in CWM.
Please refer to point 5 for further details.
Best regards,
Joana
03-05-2026 07:58 PM
Hi Joanna
You can customise cwm view of rm_story and the fields should start appearing as per that view in CWM, workspace. If you are facing challenges - Please raise a support ticket.
And, filters on the Kanban will be not exactly same as VTB but its easy to filter on any field and also save as view too.
Thanks and Regards,
Sunil B N
03-01-2026 08:14 PM
Hi @Joanna Wuu,
Have you gone through the below articles? If not, kindly use these articles; this will help you:
By the way, excellent point of view. 👍
If you find my answer useful, please mark it as Helpful and Correct. 😊
Soham Tipnis
ServiceNow Developer || Technical Consultant
LinkedIn: www.linkedin.com/in/sohamtipnis10
03-02-2026 12:36 AM
Dear @SohamTipnis,
I have reviewed all available documentation, however, I was unable to find answers to my questions.
The main concern is that when deploying CWM on a clean instance, Agile Development 2.0 will not be available, and therefore there will be no data to transfer.
Thank you for your response and for the time you have dedicated to this matter.
Best regards,
Joanna
