Display state in process flow formatter dynamically
Prabhh
Mega Guru
We need to add new state "Rejected" for Demand workflow and should be visible in process flow formatter only when state is set to "Rejected" similar to "Deferred". Can anyone please suggest what needs to be done for this?
- Prabhh
Sreeraj
Activate reject UI action first
Activate flow formatter for reject
Remove reject condition from deferred flow formatter
Open BR : dmn_demand_ProcessFlowList and add below code after line 48 :
if (gr.sys_id == 'd72f6f218f51110040f82ab2f0f92335') {
if (match) {
choices.removeChoice("9"); //remove 'Complete'
choice.setParameter('state', 'current');
} else
continue; //if rejected NOT match don't add to the choice list
this will hide rejected state in flow formatter just like deferred.
Mark answer as helpful if it works! It worked for me. 🙂
