Reference Qualifier roles=itil not working
Please help me.
I am setting up this Reference Qualifier on table Story for field Epic. Epic is a reference field referencing table Epic.
I set up this first: javascript:'stateNOT IN3,4^EQ^' + ScrumSecurityManager.getStoryDotEpic(current) and it worked.
Then I set up this javascript:'stateNOT IN3,4^EQ^roles=itil^' + ScrumSecurityManager.getStoryDotEpic(current), it doesn't work as I wanted. I want to restrict it to users with role 'itil'. The second 'Reference qual' works exactly the same as the first one.
May I ask how can I add roles to the first 'Reference qual' to make it work?
Thank you so much.
Chander Bhusha1
Hi Oliver,
The roles is not a field on the epic table so you can make use of gs.hasRole('itil') as below: Here the reference qualifier only apply if the user is not having having itil role
 javascript:if(!gs.hasRole('itil') 'stateNOT IN3,4^EQ^' + ScrumSecurityManager.getStoryDotEpic(current) ;
If you are having any else condition also then you can use this :
javascript:if (!gs.hasRole('itil')) 'stateNOT IN3,4^EQ^' + ScrumSecurityManager.getStoryDotEpic(current) ; else ------your else condition------;
Please mark answer correct or helpful if it works.
CB
Hello CB,
Thank you so so much. it worked.
I have a question, why it is not sth like this?
javascript:if(!gs.hasRole('itil')^'stateNOT IN3,4^EQ^' + ScrumSecurityManager.getStoryDotEpic(current) or javascript:if(!gs.hasRole('itil') + 'stateNOT IN3,4^EQ^' + ScrumSecurityManager.getStoryDotEpic(current)
no need to use + or ^ as AND to connect if(!gs.hasRole('itil')) and 'stateNOT IN3,4^EQ^'?
Hi Oliver,
Ya you don't have to use + side or ^ sign to put the condition as you want if the user doesn't have role then you need this reference qualifier so it will come directly : as this is will only satisfy when the role condition.
It means first part is satisfied then the reference qualifer will get applied its not addition to both the condition.
Please mark helpful.
CB
