Assessment Simulator Task 3 - Create and Comment on a Record
05-05-2026 05:38 AM
05-06-2026 07:45 AM
05-06-2026 08:12 AM
Hi @SandraC39359048, if you haven't already, it might be worth creating a new INC.
There are a couple of validation errors that can occur during this task so the fact that you're only receiving the "Did you add and post a comment?" error suggests that you raised the INC correctly, so I don't know if it being resolved and then reopened might be causing an issue or not.
I've been putting together some guides for the Micro-Cert tasks - it might/might not help but just in case: [Assessment Task Notes] Welcome to ServiceNow Micro-Cert: Create and Comment on a Record
If you're still experiencing issues then you may need to raise a support case with ServiceNow University via the Help Center
06-10-2026 03:06 AM
Im experiencing the same issue and already tried everything written in this and similar threads. Still the "Did you add and post a comment?" issue persist.
I think there is a bug here, any chance someone from ServiceNow can have a look at this? I cannot continue the training without this lab completed.
