Dictrionary Entry - Script not working as expected
joseflores3
Greetings Community
On my company we have a Dictionary Entry with a custom script, to calculate the MI TTR, right not the script is this one
(function calculatedFieldValue(current) {
// Add your code here
var miStart = current.u_mi_start.getDisplayValue();
var servRest = current.u_service_restored.getDisplayValue();
var ttr = gs.dateDiff(miStart,servRest,false);
return ttr;  // return the calculated value
})(current);
this makes a direct calculation between miStart and servRest, what we need is to have the lowes between miStart and detectionTime and the result with a dateDiff to have the TTR we have this script but is not working
var detectionTime = current.u_detection_time.getDisplayValue(); // Assuming you have a detection time field
var ttr;
if (miStart > detectionTime) {
ttr = gs.dateDiff(detectionTime, servRest, false);
ttr = gs.dateDiff(miStart, servRest, false);
})(current);
Anyone can help me to know why is not working as expected
Vishal Jaswal
Tera Sage
Hello @joseflores3
I made some minor changes and it should work:
   // Retrieve values as GlideDateTime objects
   var miStart = current.u_mi_start.getGlideObject();
   var servRest = current.u_service_restored.getGlideObject();
   var detectionTime = current.u_detection_time.getGlideObject();
   // Get the earliest time between miStart and detectionTime
   var earliestStart = miStart.getNumericValue() < detectionTime.getNumericValue() ? miStart : detectionTime;
   // Calculate TTR (Time to Restore)
   var ttr = gs.dateDiff(earliestStart, servRest, false);
   // Log the calculated values for debugging
   gs.log("TTR_VJ1 Calculation: miStart = " + miStart);
   gs.log("TTR_VJ1 Calculation: detectionTime = " + detectionTime);
   gs.log("TTR_VJ1 Calculation: servRest = " + servRest);
   gs.log("TTR_VJ1 Calculation: TTR = " + ttr);
   return ttr; // Return the calculated value
})(current);
Dummy Test: (Selected date time is Pacific Standard Time)
After Business Rule
Logs (UTC):  MI Start: 8:30 pm and service restored: 10:35 pm -- TTR: 2 hours 5 minutes
Hope that helps
Hope that helps!
Hi Vishal,
I deepdive into this using your script and with some values modifications this script worked as expected
thank you
