CSA and CAD Exam passing criteria
VarshithY
I have doubt regarding both CSA and CAD exams, which says that 70% is the cutoff score for certification. But how are questions evaluated :
1.Are all 60 questions are evaluated and total score is compared with cutoff score.
2.Or all the questions are divided into six sections and a person has to score atleast 7 question in each section to get certified.
3 ACCEPTED SOLUTIONS
Dr Atul - LNG
Hi @VarshithY
Tough to say, as passing %age is never disclosed by SN.
Simon Hendery
Hi @VarshithY
Everything you need to know about exam cut scores and domain percentages is explained here:
https://www.servicenow.com/services/training-and-certification/journey/#/lessons/VlL6wxYvEjMjCGwx-HE...
You'll see that it specifically states that the cut score is NOT always 70%.
The answer to your question is 1. As per the info in the link: "your overall pass/fail status depends solely on your total correct answers compared to the cut score".
Tanushree Maiti
Hi @VarshithY ,
As per my exp with Certification (12 mainline certs) , ServiceNow never disclose the exam cutoff score anywhere.
Also (this is not documented any where) , An exam proctor once said to me (from his exp) , if you fail in any of the exam domain/section (e.g you have 6 sections, in 5 sections  you got approx 90 but in one section , it is 40)  then also you will fail the exam . If All sections you pass then the total sections' score will be averaged.
So make sure you have covered all the mentioned domains/sections as per exam blueprint fully prior to give the ServiceNow Mainline exams.
Tanushree Maiti
Tanushree Maiti
Hi @VarshithY ,
Tanushree Maiti
@Tanushree Maiti - that is not correct.
If you're going to answer questions on this subject, please read the guidelines, as per the link I supplied, so you understand how the exam scoring process actually works.
