how we Abort some actions in flow designer in flow designer?
07-20-2022 09:59 PM
is their any option to Abort in flow designer ?
07-20-2022 10:09 PM
07-23-2022 01:43 AM
Hello @rani
If my Answers helps you yo Solve my query Please Mark it as CORRECT,as it will help other to find the solution.
07-21-2022 07:48 AM
Hi Rani,
In OOB Actions you can't do much to abort the action but you can leverage end logic to end the flow at point required.
In case, if you have custom action then you use throw exception or to stop execution and break out of action.
Muhammad
