05-20-2025 11:28 AM
Hello Everyone,
We have identified an issue where, following the closure of a Major Incident (P1 incident), duplicate problem records are being created. One record is generated under the user's name, while another is created by the system.
This occurrence appears to be random.
Also, issue is reproduceable in the the lower instance.
Could anyone assist in identifying the root cause of this issue? Thank you.
05-21-2025 04:24 AM
I shared solution for this recently here, sharing it again
Automatic problem record is getting created when M1/M2 incident getting resolved
1) either deactivate that subflow
OR
2) Remove that Step 8, remember you will have to update the playbook in the correct scope
OR
3) Update that flow action
05-21-2025 05:03 AM
05-21-2025 06:43 AM
Hello @Ankur Bawiskar ,
I'm not getting option to deactivate this subflow, could you please suggest on this ?
05-21-2025 07:00 AM
did you check the other 2 options
OR
3) Update that flow action in correct scope
