Email body issue it contains duplicate details
Sarah Bouil
Hi, I am trying to delete the itil role from users who are no logged in system last 60 days. I am able to delete the itil role but I am having issue while sending email with itil users removal list in email body. The email boday contains duplicate users list.
Code:
var ITIL_ROLE_ID = '282bf1fac6112285017366cb5f867469';
function getContainingRoles(roleSysId, rolesToRemove) {
    var grRoleContains = new GlideRecord('sys_user_role_contains');
    grRoleContains.addQuery('contains', roleSysId);
    grRoleContains.query();
    while (grRoleContains.next()) {
        var containingRoleId = grRoleContains.role.toString();
        if (!rolesToRemove.includes(containingRoleId)) {
            rolesToRemove.push(containingRoleId);
            getContainingRoles(containingRoleId, rolesToRemove);
var rolesToRemove = [ITIL_ROLE_ID];
getContainingRoles(ITIL_ROLE_ID, rolesToRemove);
var removedUsers = [];
var userGr = new GlideRecord('sys_user');
userGr.addEncodedQuery('active=true^last_login<=javascript&colon;gs.beginningOfLast60Days()^roles=itil^web_service_access_only=false^ORinternal_integration_user=false^user_nameNOT LIKEadmin^user_nameNOT LIKEsvc^nameNOT LIKEsvc');
userGr.query();
gs.log('User count: ' + userGr.getRowCount());
while (userGr.next()) {
    gs.print('Processing User: ' + userGr.getDisplayValue('user_name'));
    var groupList = [];
    var userRoleGr = new GlideRecord('sys_user_has_role');
    userRoleGr.addQuery('user', userGr.sys_id);
    userRoleGr.addQuery('role', 'IN', rolesToRemove.join(','));
    userRoleGr.query();
    while (userRoleGr.next()) {
        gs.log('Removing explicit ITIL role for user: ' + userGr.user_name);
        //userRoleGr.deleteRecord();
        removedUsers.push({
            userId: userGr.getDisplayValue('user_name'),
            email: userGr.getDisplayValue('email')
    gs.print('Test01-removedUsers: ' + removedUsers.length);
    var groupMemberGr = new GlideRecord("sys_user_grmember");
    groupMemberGr.addQuery("user", userGr.sys_id);
    groupMemberGr.query();
    while (groupMemberGr.next()) {
        var groupRoleGr = new GlideRecord("sys_group_has_role");
        groupRoleGr.addQuery("group", groupMemberGr.group);
        groupRoleGr.addQuery("role", 'IN', rolesToRemove.join(','));
        groupRoleGr.query();
        if (groupRoleGr.next()) {
            gs.log('User ' + groupMemberGr.getDisplayValue('user') + ' removed from group ' + groupMemberGr.group.name + ' due to License Optimization');
            groupList.push(groupMemberGr.group.name.toString());
            //groupMemberGr.deleteRecord();
    gs.print('Test01-groupList: ' + groupList.length);
if (removedUsers.length > 0) {
    var emailBody = "The ITIL role has been removed from the following users due to inactivity:\n\n";
    for (var i = 0; i < removedUsers.length; i++) {
        var user = removedUsers[i];
        emailBody += "Name: " + user.name + ", User ID: " + user.userId + ", Email: " + user.email + "\n";
    var email = new GlideEmailOutbound();
    email.setSubject('ITIL access removed users list');
    email.addRecipient('survey.user@email.com');
    email.addRecipient('test1@example.com');
    email.setBody(emailBody);
    email.save();
    email.send();
    gs.log('Notification email sent to user');
Email body: email body contains the user details multiple times, highlighted below.
It should be like below.
What is the issue in my code? kindly help on it.
Hi @Sarah Bouil ,
for your 4th use case I have shared the updated code -
Kindly replace these five lines in your code.
//Replace These 5 lines from you code -
//Replace the above with the below code
var daysAgo = gs.daysAgoStart(60); // Get date for 60 days ago
    var emailBody = "The following users had their 'itil' role removed because they have not logged in for 60 days:\n\n";
    // Query sys_user for users who haven't logged in for 60 days and have the 'itil' role
    userGr.addEncodedQuery('last_login_time<=' + daysAgo + '^roles=itil'); // Users who haven't logged in for 60 days and have 'itil' role
    userGr.addActiveQuery(); // Only active users
    userGr.query();
    emailBody += "Name: " + userGr.name.toString() + ", User ID: " + userGr.userId.toString() + ", Email: " + userGr.email.toString() + "\n";
This code will validate any duplicate user detail is not added in your email body.
Hope this help you.
Moin
Hi Moin,
I have updated the code as you mentioned but the email body doesn't contains any data, it is showing as empty body with user details.
Code:
var ITIL_ROLE_ID = '282bf1fac6112285017366cb5f867469'; // sys_id of the itil role
// To find out all roles containing the given role
// Array to keep track of roles to be removed
// Query to get itil role users who are not logged in 60 days, excluding admin and svc account users
userGr.addEncodedQuery('active=true^last_login<=javascript&colon;gs.beginningOfLast60Days()^ORlast_login_timeISEMPTY^roles=itil^web_service_access_only=false^ORinternal_integration_user=false^user_nameNOT LIKEadmin^user_nameNOT LIKEsvc^nameNOT LIKEsvc^nameNOT LIKEDQM');
userGr.query();
gs.log('Total user count: ' + userGr.getRowCount());
    gs.log('Processing User: ' + userGr.getDisplayValue('user_name'));
    var groupList = []; // Store groups details from which the user will be removed
    // Removing itil role if itil is explicitly added to user
    userRoleGr.query();
        removedUsers.push({
    gs.log('Test01: ' + removedUsers.length);
    // Removing a user from itil groups if the itil role is inheriting
    gs.log('Test02: ' + groupList.length);
    var emailBody = "Hi Team,\n\n" + '<br>' + '<br>' + "The following users had their 'itil' role removed because they have not logged in system for 60 days:\n\n" + '<br>' + '<br>';
    var userGr1 = new GlideRecord('sys_user');
    userGr1.addEncodedQuery('active=true^last_login<=javascript&colon;gs.beginningOfLast60Days()^ORlast_login_timeISEMPTY^roles=itil^web_service_access_only=false^ORinternal_integration_user=false^user_nameNOT LIKEadmin^user_nameNOT LIKEsvc^nameNOT LIKEsvc^nameNOT LIKEDQM');
    userGr1.query();
    while (userGr1.next()) {
        emailBody += "Name: " + userGr1.name.toString() + ", User ID: " + userGr1.user_name.toString() + ", Email: " + userGr1.email.toString() + ", Last login: " + userGr1.last_login.toString() + "\n" + '<br>';
    email.addRecipient('test@gmail.com');
    email.setBody('<br>' + 'Regards' + ',' + '<br>' + 'Support Team.');
    email.save();
    email.send();
    gs.log('Email sent with list of itil role removed users');
Notification Email body:
Could you please help me to fix the issue?
