Flow designer "Gateway Timeout" error and for each flow logic cancelled.
Niranjan2
flow is taking longer time to execute and am getting "Gateway Timeout" error.  When I check the 'executions', for each flow logic status is cancelled.
SANDEEP28
@Niranjan2 what is configured in the flow ? Are you calling any API ? Can you explain issue properly
Hi @SANDEEP28
I have a similar issue as below thread, didn't find solution for 'Gateway Timeout' in the below thread as well.
https://www.servicenow.com/community/itsm-forum/flow-designer-for-each-logic-error/m-p/537475
Trigger is Monthly and Actions -> Look up Records on Account table with a condition Ex (Active = true) -> then For Each item in -> look up Account records -> Account then Applying Template and doing some other stuff this how the flow goes. attached Screen shot.
Niranjan2_0-1711045194874.pngexecution taking long time and at the end "Gateway Timeout" error.
Sumanth16
Mega Patron
Hi @Niranjan2 ,
Please refer to below thread:
If I could help you with your Query then, please hit the Thumb Icon and mark it as Correct !!
Thanks & Regards,
Sumanth Meda
Hi @Sumanth16
