Help in Client Script: If user belongs to CMDB assignment group, he can edit a field in cmdb table
ArushiG
Hi team,
Please help me with a client script on cmdb_ci_hardware table:
If a user belongs to cmdb_ci_hardware table, he should be able to edit the new field "External IP". I've written the below:
function onLoad() {
    var usrdetail = g_user.getUserID();
    var gr = new GlideRecord('sys_user_grmember');
    gr.addQuery('user', usrdetail);
    gr.addQuery('group', '47d86fe1db7f845055434cb11596192a');
    if(gr.next()){
        g_form.setVisible('u_external_ip',true);
        g_form.setReadOnly('u_external_ip', false);
    else{
        g_form.setVisible('u_external_ip',false);
        g_form.setReadOnly('u_external_ip', true);
13 REPLIES 13
No @ArushiG
Just write your script in script field that's it. It will work.
Kindly mark my answer as helpful and accept solution if it helped you in anyway. This will help me be recognized for the efforts and also move this questions from unsolved to solved bucket.
Shivalika
My LinkedIn - https://www.linkedin.com/in/shivalika-gupta-540346194
My youtube - https://youtube.com/playlist?list=PLsHuNzTdkE5Cn4PyS7HdV0Vg8JsfdgQlA&si=0WynLcOwNeEISQCY
Thank you, I'll try that and update here
@ArushiG
Or if not all members at once -
answer = gs.getUser().isMemberOf('47d86fe1db7f845055434cb11596192a')
That's it. This one line is enough.
Shivalika
Thank you, I will go online in sometime, I'll try it and will reply, thank you
Sure @ArushiG
Kindly mark my original answers as solution if that works for you.
Shivalika
