How to Control Attachments for RITMs After a Specific Status.
Ryota
Is it possible to implement this using a Business Rule: prevent attachments from being added or deleted for RITM records of a specific catalog item when the state is Work in Progress or later?
Ankur Bawiskar
@Ryota
yes you can use before insert before delete business rule on sys_attachment
Before Delete and Before Insert
Condition: current.table_name == 'sc_req_item'
Script:
    var ritm = new GlideRecord('sc_req_item');
    if (ritm.get(current.table_sys_id)) {
        if (ritm.cat_item == 'YOUR_CATALOG_ITEM_SYS_ID' && ritm.state >= 2) { // 2 = Work in Progress
            gs.addErrorMessage('Attachments cannot be added for this RITM in Work in Progress or later state.');
            current.setAbortAction(true);
})(current, previous);
nayanmule
@Ryota  , well you can do this in two ways.
1. Client script (for UI effect) on RITM table -
function onLoad() {
   // Check if the RITM state is 'In Progress' (value 2, verify in your instance)
   if (g_form.getValue('state') == '2') {
      g_form.disableAttachments();
2. Using Business Rule (for server validation - this is more preferred since you want to restrict both adding and deleting the attachments)
Before Business Rule
Table - sys_attachment
Update and Delete to be checked -
      if (ritm.state == '2'  && ritm.cat_item =='catalog item sys_id') {
         gs.addErrorMessage('Attachments cannot be added for this RITM when it is In Progress.');
If my response has helped you, mark it as helpful and accept the solution.
Nayan
nayanmule
@Ryota  , my solution should have also worked for you.
Kindly accept the solution and closed the thread.
Nayan
