Issues with Dot-Walked Updated_by in BR — Works in PDI but Not in Our Dev Instance
rhyannagood
Hi everyone!
I'm encountering an issue with a Business Rule that’s designed to transition a case from Suspended to WIP when a comment is added. The Business Rule includes a condition that requires sys_updated_by (the updater of the record) to match the value retrieved via a dot-walk from the opened_for field (i.e., opened_for.updated_by).
What’s happening:
  • In my (PDI):
    The configuration works as expected, and the Business Rule fires when the condition is met.
  • In our Organization’s Dev Instance:
    When I configure the condition as “Updated by is same as” and then dot-walk to the opened_for.updated_by field, the Business Rule does not fire. However, if I simply use “Updated by is same as Updated by” (without dot-walking), it works fine.
I’d appreciate any insights or suggestions on how to resolve this or adjust the configuration, so the intended logic is consistently met.
Thank you in advance!
2 ACCEPTED SOLUTIONS
Ankur Bawiskar
@rhyannagood
Things to check
1) are you sure Opened for field is populated?
2) shouldn't you check the userID to check if the user who updated is the same as Opened For user
Updated by [SAME AS] OpenedFor->UserID
Chaitanya ILCR
Giga Patron
Hi @rhyannagood ,
It should update by same as opened_for.userid
like @Ankur Bawiskar mentioned
are you setting the value of the state to WIP in the actions?
check if the abort action is checked and uncheck it
please share the screenshot of actions tab in the BR
or check if there is any other BR or anylogic which is aborting the action of this
Chaitanya
@rhyannagood
Please ensure the BR is configured correctly as per the other instance
Chaitanya ILCR
Giga Patron
Hi @rhyannagood ,
Chaitanya
Hi Giga! Prior to this I did attempt opened_for.userID & that did not work. I just re-reviewed & it looks like everytime I went back & made changes the ' actions' tab did not stick( so the BR didn't run because the actions field was empty). All set now! Thank you so much!
