Need to create a dashboard for Problem
KunalKothare
Need to create a dashboard for Problem as per attached in Classic and new UI
Bhavani Shankar
Hi @KunalKothare
If you want to create dashboards with widgets such as the ones in the screenshot, you have to explore the Performance analytics solution. With this you will be able to create dashboards with historical data and also identify trends for the metrics you need.
Here is the docs URL
https://docs.servicenow.com/bundle/washingtondc-now-intelligence/page/use/performance-analytics/conc...
If my response helped, please do leave a thumbs up 👍
AndersBGS
Hi @KunalKothare
This is a dashboard crashed with performance analytics. Do you have the performance analytics subscription in your instance. If yes, where do you face problems?
Best regards
Anders
