Read ACL should not have GlideRecord/GlideAggregate/GlideRecordSecure in script.
prityshawex
Hello All,
Hope all are doing good !!
ACLs (Security rules) should not have GlideRecord/GlideAggregate in script
We have a custom ACL written as shown below using GlideRecord. How can i replace this code so that it does not use  GlideRecord query. or is it even possible in this case?.
var gr = new GlideRecord('sys_user_delegate');
gr.addQuery("user", '' + current.n_1_validator.sys_id);
gr.addQuery("delegate", '' + gs.getUserID());
gr.addEncodedQuery("starts<=javascript&colon;gs.endOfToday()");
gr.addEncodedQuery("ends>=javascript&colon;gs.beginningOfToday()");
gr.setLimit(1);
if (gr.next()) {
    answer = true;
    answer = false;
Prity
Chaitanya ILCR
Giga Patron
Hi @prityshawex ,
This type of requirement definitely require scripting,
You do following instead.
create a role
since it's a read operation create an acl and add the created role to the acl and assign the role to correct users (you can automate this assignment (by BR) and removal( by scheduled job))
and create a query BR and restrict the access  to those specific records by adding the same logic in the query BR
OR
if you don't want to see the the code and find to have a single line in the ACL like @J Siva suggested create a script include and add the logic to the script include and  call the script include in the ACL
Chaitanya
Creating a Query Business Rule to hide specific data is triggering another healthscan/scan engine (impact) finding because of another definition...
Mark Manders
Consider to create a security attribute for this. You can just put that in place on any ACL you need. It makes it reusable (https://www.servicenow.com/docs/bundle/yokohama-platform-security/page/administer/contextual-securit.... There almost is no need for scripting in the script field of an ACL anymore.
