How to create an incident from record producer through virtual agent?
I want to create an incident with variable section through virtual agent, the same way we create through record producer.
I tried the the way by which we create RITMs but it's not working.
Several ways possible. Also depending on where the information for those variables would come from.
Though, easiest would be to add a question_answer record scripted. Like below. This would already be similar as having variables when submitted through a record producer.
Personally I would consider doing this more dynamically, fetching the variables from the record producer, etc.. Though below would already work.
var grAnswer = new GlideRecord('question_answer');
grAnswer.initialize();
grAnswer.setValue('table_name', 'incident');
grAnswer.setValue('table_sys_id', 'sys_id_of_your_created_incident, maybe something like vaInputs.create_incident');
grAnswer.setValue('question', 'sys_id_of_the_variable');
grAnswer.setValue('value', 'value_for_the_variable');
grAnswer.setValue('order', '100/200/300/etc');
grAnswer.insert();
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
LinkedIn
Community article list
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
9 REPLIES 9
grAnswer.insert();
Kind regards,
Mark
LinkedIn
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
Thank you so much Mark
Thank you Mark for the details.
I am still unable to create a Incident record with the Variables.
I have Catalog Item and Custom Form has been created on ServiceNow to create the request Ticket for this Item.
I am Trying to utilize those variables from Virtual agent to submit the request.
I tried to set values for the questions in Incident Table but It did not worked.
I am using Quebec..
Is there a way to create an Incident using a Record producer? Populate the variables dynamically on the Record Producer and re-use the Record Producer script held within the Record producer? Don't want to replicate the logic within the Record producer inside my VA topic
Ayman
