do while loop is not working in flow designe
JayS56800927307
Hello Guys,
I have used the below code in the flow designer for the print logs. but it is running only for the one times in flow designer.
var loop count=0;
var i= 0;
do {
loop_count=loop_count+1;
console.log(num);
i++;
while (i < 5);
output: 1,2,3,4,5
here loop count is integer .it is running only one time only.
i have added add operation over here one loop_count  but not getting output 1,2,3,4,5 system log. please help
2 ACCEPTED SOLUTIONS
newhand
@JayS56800927307
YES,because you writed [less than 5] at the [until] part ....
The first time you run the loop...the  [loop_count] becomes 1  ,and it  is  [less than 5]  ,so the loop is ended.
you need to change [less than 5] to [more than 5]...
Please mark my answer as correct and helpful based on Impact.
As per the image you provided earlier, your flow variable's backend name is not loop_count. See the below image which you provided.
So, in your script, use the proper backend name of your flow variable. In my case it was loop_count.
return fd_data.flow_var.<backend_name_of_your_flow_variable> + 1;
JayS56800927307
i have copied your flow but it is not working for me. may I mad some mistake .
one question do we need to set flow variable as first step?
No there is no need to set variable at first step.
Flow
Output
JayS56800927307
This the error
JayS56800927307
Hello @Muhammad Khan ,
Could you please give ana example of for each item for particulate usecase. ?
Jay Shah
