Flow Designer: “All must approve” & “anyone rejects → RITM rejected” using ApprovesAllU[...]
BiswalNayak
var approvers = fd_data.flow_var.groupmanager;
return "ApprovesAllU[" + approvers + "]";
This correctly enforces all approvers must approve before proceeding. I also need: if anyone rejects, the flow should go to the reject branch and reject the RITM. Here the reject branch is not working. So, what is the solution to work both of the conditions ?
Anand__99
Hi @BiswalNayak ,
You can configure this as per the below screenshot:
Or if want to use script:
"ApprovesAllU[" + approvers + "]OrRejectsAnyU[" + approvers + "]";
Anand
Hi @BiswalNayak ,
If my response helped you solve your query mark this as correct/helpful.
