Flow Designer REST Connection
Mike S1
Hi all,
I'm working through this great example for setting up a REST integration: https://www.servicenow.com/community/developer-articles/outbound-rest-integration-using-flow-designe...
I set it up in my PDI with no problem, but as I shifted it over to the dev instance, the Connection dropdown on the Connection Alias isn't populating on the REST Step. Here's what I'm seeing trying to set it up:
I looked for missing roles but didn't see anything. Anyone run into this? Missing plug-in?
-Mike
Daniel Draes
Hm.. that sounds weird. I would raise a case with support on it. Maybe a plugin has not been activated correctly.
