11-27-2023 01:35 AM - edited 11-27-2023 01:39 AM
Is there a method in flow designer to retrieve the triggered outputs from the inbound mail in flow designer?
I am interested in accessing the target record from the triggered output of the incoming mail.
The purpose is to locate the record associated with the incoming mail.
11-27-2023 04:12 AM
You can get the sys_id of the target record from the data pill Trigger - Inbound Email -> Email Record -> Target. At the end of the list.
Please mark my answer helpful and accept as a solution if it helped 👍✔️
11-27-2023 04:54 AM
Figured out the mistake i done. Instead of choosing From the Email record pill, i took it directly
Thanks a lot
11-27-2023 05:15 AM
@chandra shoban1 Expected that, so asked you to share the Config. I'm glad it helped 👍
